I received my new Versa 4 yesterday. This is my 4th Fitbit, Charge2, 2 Versa2, and now Versa4. Even on strong, this vibrate is barely detectable, and certainly not enough to actually alert me. How do I get a replacement? A Fitbit without alerts is not useful.
Hi @mark8adams - if you had a Versa 2 before where the vibration was good you will certainly notice the vibration on Versa 4 watches is barely detectable.
Before going to a replacement for a fault, check the vibration properly.
There are 8 basic different vibrations but the easiest to check it out is to simply setup a test alarm which has the strongest of the vibrations but it will definitely be weaker than on a Versa or Versa 2.
