03-21-2023
09:31
16:18
JuanFitbit
03-21-2023
09:31
16:18
JuanFitbit
I cant log into amazon to set up alexa on Versa 4 as it takes me to US site and my amazon and alexa account is UK. Followed all the steps from the Fitbit app with no other problems but need to get to amazon.co.uk Any help will be appreciated.
Thanks
Best Answer03-21-2023 13:54
03-21-2023 13:54
Go to the US site and log in if the correct region is setup, it should auto-adjust.
03-21-2023
12:07
10:33
03-21-2023
12:07
10:33
@Keith3784 , Nice to see you around. Thank you for your message.
Do you use the Alexa skills?
Do you have the Amazon Alexa app also installed on your mobile device?
In the meantime, make sure that the location on your phone, Fitbit app and Amazon Alexa app (if installed) are on the UK or your preferred one.
Best Answer03-21-2023 13:36
03-21-2023 13:36
Hi Juan, thanks for the message.
I have the Alexa Fitbit skills working on my echo dots at home and also have the Alexa app on my mobile.
Location is correct on all devices (set to UK)
03-21-2023 13:54
03-21-2023 13:54
03-21-2023 15:07
03-21-2023 15:07
03-21-2023
16:17
10:36
03-21-2023
16:17
10:36
@SunsetRunner , Thank you for your tip.
@Keith3784 , Nice to read that everything is working fine.
Could you mark the Best Answer that help you or describe what you did so that other users in the same situation can find the solution easily?
