05-24-2024
09:33
14:01
05-24-2024
09:33
14:01
Is there a setting to enable or disable to allow Fitbit to sync while no data is available? I’m active duty military and don’t always have access to WiFi or cellular data for extended periods. Is there a way to sync just with the Bluetooth function?
Best Answer05-24-2024 10:23
05-24-2024 10:23
It always does the bluetooth first part of the sync to your phone when it can reach that. As far as the next part to the fitbit internet database via wifi or cell, that just happens from phone when available, no setting needed. Not sure I have times right, but believe your device will store detailed data for about a week, then switch to keeping summary data for about a month. The same thing happens sometimes when people go on longer camping trips away from cell service, and just sync when they get back, without making any special settings.
Best Answer05-24-2024 16:26 - edited 05-24-2024 16:26
@Gibsp I want to add some additional information. If you can’t sync for long time periods, the time on your Versa 4 can drift and you can’t fix it. It’s unfortunate that Fitbit doesn’t have offline sync available. There are no plans to change this. Sorry.
Been there. Done that. USN, Ret.
Laurie | Maryland
