06-07-2023
20:59
18:00
AndreaFitbit
06-07-2023
20:59
18:00
AndreaFitbit
Can anyone let me know if the Glance watch face works with Dexcom G7?
Best Answer06-10-2023 09:12 - edited 06-10-2023 09:13
@bkushner The Glance watch face is available for the Versa 4. As you probably know, Glance supports multiple data sources, including Dexcom. Glance site Although the Versa 4 isn't specifically listed, I just think the page needs to be updated. I think you will get an answer faster if you contact Ryan Mason, the developer, for more help. Tap on your profile avatar > Versa 4 > slide the toggle to clocks > search for Glance. You can email him directly by tapping on the Contact Developer at the bottom of the page.
Laurie | Maryland
06-08-2023 01:33
06-08-2023 01:33
Hi @bkushner - here is the dexcom site who may be better placed to reply.
I found this site which may help as the Sense 2 and Versa 4 share the same platform. best smartwatches for dexcom-g7
However the implementation may not be as good as on a Versa 3 which has more features including full 3rd party support.
06-08-2023 03:21
06-08-2023 03:21
@Guy_ it surprises me they put Sense 2 on that list. No 3rdparty support means the Glance watch face won't get any updates from developers which makes it hardly "best" for that purpose.
Best Answer06-08-2023 03:40
Laurie | Maryland
06-26-2023 12:13 - edited 07-04-2023 16:54
I have this problem too. Versa 4 can download the Glance watchface…. But it is not transmitting any share or followed Dexcom 7 data !!…. I’ve gone through all the required steps numerous times but Bubkiss , Nada , Nothing….
