07-25-2023
12:08
04:06
07-25-2023
12:08
04:06
Am I missing something? With Versa 2 the timer would continue to vibrate until I selected the confirm check mark to cancel the timer. Are there any settings in the Versa 4 to keep the vibrations on till confirmation?
Hi, @Scott_L - the timers on the Versa 4 are fairly rudimentary but the vibrations should continue once the time is up until you clear it or for about 22 seconds when it auto cancels and the display may go off well before.
If this not the case try holding the button for 10 seconds till it vibrates and the logo appears and wait for it to start again, this may fix it.
You are right, the older more sophisticated watches had about a minute before it auto cancelled.
Not only that the vibrations on a Versa 2 were more pronounced.
Thank you for the response. Wasn’t sure how the timer worked with the Versa 4. I also found I could set the vibrations to “strong” vs “light”. Perhaps I wasn’t feeling the light vibrations before but tried holding down the button for 10 seconds as you suggested. Now the Versa 4 is working as you described above and all is good now. Thanks!
Hi there, @Scott_L. Welcome to the Fitbit Community Forums. I'm glad to hear your Versa 4 is working as expected after following @Guy_'s suggestion.
For more information about this feature, please see How do I set a timer or use the stopwatch on my Fitbit device?
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members.
