02-03-2023 01:18
02-03-2023 01:18
Hi! I just got a new Fitbit since yesterday, a Fitbit Versa 4. When starting a hiking (or cycling or running) training and including GPS, it keeps saying that there is no GPS signal.
I tried every solution as found on the Fitbit site and this community. But nothing seems to solve this issue. Yes, GPS location for the app is turned on.
02-04-2023 10:25
02-04-2023 10:25
I found a solution in another post.
02-03-2023
03:35
10:42
02-03-2023
03:35
10:42
@NicoleRoffa Welcome to the Fitbit community!
Sad to hear that your new Versa 4 isn't working as expected. If you've already tried restarting it by pressing and holding the side button for 10 seconds without success, there might be technical issues with your device. Hence I'd suggest contacting Fitbit support to get further assistance:
Fitbit Support Contact
02-03-2023 05:11
02-03-2023 05:11
I've been in contact with them, but no luck.
02-03-2023 05:23
02-03-2023 05:23
@NicoleRoffa Just to be sure: If you're doing one of the exercises you mentioned above, you're getting a red GPS indicator like this?
02-03-2023 05:38
02-03-2023 05:38
When starting a training, I first see a white/grey indicator and a minute or so later it turns red.
02-03-2023 06:01
02-03-2023 06:01
@NicoleRoffa When you've tried restarting your Versa 4 by pressing the side button for 10 seconds, and if you aren't getting GPS reception on your Versa 4 in open field while GPS on your phone is working, I can't see another option than your Versa 4 having technical issues.
02-04-2023 07:48
02-04-2023 07:48
That is a bummer. I only got this Fitbit since thursday.
This Versa 4 doesn't have the option to use the gps from my phone yes? Just like Versa 2 does!
02-04-2023 10:25
02-04-2023 10:25
02-04-2023 12:44
02-04-2023 12:44
@NicoleRoffa Thanks for your feedback, have fun with your Versa 4!
