I have tried all the suggestion in the prior post on this subject...it's very intermittent and very frustrating as I have been cycling the same area the past 2 years with no issues until this year starting in April tracking is not working....would it be the Fitbit and tired and doesn't want to work again? this is the only suggestion I can come up with...does anyone know of a better tracking device
Best AnswerHi @Lowender, some Fitbit watches have onboard GPS while others piggyback on your phone's GPS. Before you replace your Fitbit make sure that the problem is not the phone, or the connection between the Fitbit and the phone. If the problem is the phone's GPS, then replacing the Fitbit won't solve the problem. Your fitbit's documentation will tell you whether it has an onboard GPS.
