11-20-2024
11:08
04:10
CrisVillaFitbit
11-20-2024
11:08
04:10
CrisVillaFitbit
I have recently purchased a Versa 4, was looking at all the clock faces and kept seeing group storage but I didn't know what it was. I hope this is helpful to someone:
The "Group Storage" feature on Fitbit clock faces, such as Dash, refers to how the clock face manages and stores data. This can include user preferences, settings, or activity metrics the clock face uses to function or customize its display. Here's what it typically means:
Custom Settings and Preferences: If the clock face allows for customization (e.g., changing colors, displaying specific metrics), these preferences are stored locally on the device in the group storage.
Data Caching: The clock face might cache activity data (like steps, heart rate, or distance) to avoid fetching it repeatedly from Fitbit's API, saving battery life and improving performance.
Syncing Across Devices: For specific Fitbit clock faces, group storage can help save settings so they persist when switching between devices or reinstalling the clock face.
Moderator edit: edited title to clarity.
Hello and welcome to the Fitbit Community, @Quietly.
Thanks for sharing this important information about the 'Group storage' with the clock faces of your Versa 4, this will definitely help other users in the community.
I also invite you to check if your Versa 4 is updated, here are the steps how to do so.
