12-30-2023 05:01
12-30-2023 05:01
I replaced my Charge 4 with a Versa 4 and noticed that there is a huge difference in my heart rate while exercising. For example, when wearing the Charge 4 on the Stairstepper,my heart rate would run up to the 150 bpm range on the difficult parts of the canned routine I use. With the Versa 4, I barely make it into the 100 bpm range using the same routine at the same settings. Is there a calibration that needs to be done?
19:22
19:57
EstuardoFitbit
12-30-2023
19:22
19:57
EstuardoFitbit
Hi @EdorphinAddict - this is because the Versa 4 has difficulty registering a Heart rate when moving repetitively, some under read and others over read, whereas older devices produced a more accurate result.
Best Answer12-31-2023 04:34 - edited 12-31-2023 04:34
The only calibration that will fix the problem is going back to Charge 4🤷
