02-08-2024
01:25
03:37
02-08-2024
01:25
03:37
Hi all
How do you delete an alarm set on the Versa 4? Not just to turn it off but to actually delete it.
Have googled and non of the tips/tricks there work!
Thank you
Wendy
Hi @WendyD1970 - tap the watch button, select Alarms, select the Alarm to delete, with the ON and Off buttons underneath, then scroll the watch face all the way to the bottom and tap on Remove.
Hiya Guy
Must be me being dumb, I've selected the alarm to delete but only get an option to add a new alarm. No option to remove 😞
Thank you though.
Best AnswerHello
Have faffed a bit more and managed to delete it.
Thank you again
@WendyD1970 - when you tap on the alarm to delete, you should see the 2 icons to turn on off the alarm, then when you scroll up you see the options, for days of the week etc. and after that Remove. Try with the alarm set on and also set off.
If you don't see the icons or the list of options can you go to Watch Settings, About Versa 4, System info and do you have version 195.86?
