01-11-2023 06:58
01-11-2023 06:58
I have read previous entries on the FitBit website on how to delete an alarm and I have had no luck. Every step directs me to an option I don't have, either on my phone, account or watch.
Somehow during the first week I had the Versa 4 I set multiple alarms for 6:30am. I need to delete them. Right now as it's 10am, my alarms aren't even showing up on my Versa 4. I think they only show up around normal bedtime which is insane. I previously had a Versa 2 and it was much easier to use. I am regretting my purchase.
01-12-2023
04:45
16:36
01-12-2023
04:45
16:36
@RSC2337 Welcome to the Fitbit community!
I've just tried deleting an alarm on my Versa 4 and found this method working perfectly:
Tap the side button on your Versa 4 to show all installed apps. Then tap on the Alarms app to open it. You should now see a list of all alarms that are set on your device. Tap on the alarm you want do delete. Now scroll down to the Trash/Remove button. Finally confirm that you really want to delete this alarm.
01-12-2023
04:45
16:36
01-12-2023
04:45
16:36
01-12-2023
09:15
16:35
01-12-2023
09:15
16:35
Hi @RSC2337 - try restarting the watch.
See also How do I manage alarms on my Fitbit device?
01-14-2023 06:23
01-14-2023 06:23
Thank you so much! Worked perfectly.
01-14-2023 11:02
01-14-2023 11:02
@RSC2337 You're welcome!
Thanks for your feedback. Glad I could have helped you.
