12-10-2024
14:33
04:41
12-10-2024
14:33
04:41
I entered one of the custom home screen displays. Went to check turn on turn off display in settings and now I have a home screen I did not select and I can't find a way to get back to what I want.
12-11-2024
04:46
20:07
EstuardoFitbit
12-11-2024
04:46
20:07
EstuardoFitbit
Hi there, @Bolto. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention. I understand your concern, I will do my best to help you with this.
If you saved your original clock face you can switch between the new one and the old one. Though, keep in mind that this will work only if you saved the clock face you're looking for. To see your saved clock faces from your watch, open the Clocks app (available on certain devices) and swipe to find the clock face you want to use. Tap to select it. On Versa 4, you can also press and hold your finger on your current clock face to switch between saved clocks.
To see your saved clock faces in the Fitbit app, tap the Today tab > devices icon > your device > Gallery. See your saved clock faces in My Clocks.
12-11-2024
04:46
20:07
EstuardoFitbit
12-11-2024
04:46
20:07
EstuardoFitbit
12-11-2024 04:54
