10-24-2022
13:25
09:49
10-24-2022
13:25
09:49
How do I set-up exercise cues on a Versa 4? I found the area where it is listed, but there doesn't seem to be a way to set a cue up. For example, I want to be notified each mile when on a run or walk.
Thanks for any advice
Best Answer10-24-2022 16:00
10-24-2022 16:00
Before you hit the arrow to start your walk or run scroll up on Versa 4 it has different cues you can set up.
Best Answer10-25-2022 08:10
10-25-2022 08:10
Don't see anything when I try to scroll up on the main exercise screen on the watch.
Also, whn I hit the run or walk icon on the watch, it just starts the timer immediately.
Best Answer10-25-2022 09:58
10-25-2022 09:58
Go to Exercise app first (press button, select Exercise) not to the exercise shortcuts tile. Exercises from that tile start automatically (it's dumb but it is what it is).
Best Answer10-25-2022 17:36
10-25-2022 17:36
You have to go to the exercise app, before pressing the arrow to start you scroll up and you can set up cues.
Best Answer10-28-2022 07:19
10-28-2022 07:19
