08-21-2023
11:20
04:49
08-21-2023
11:20
04:49
How do I had a type of exercise such as Yard Work?
Hello there, @Altoid4ever. Thanks for stopping by in the Fitbit Community Forums.
All the exercise shortcuts that you will find in the Exercise section are specifically designed to track the most out of each type of activity. The algorithms have been fine tuned to get more accurate data for each different exercise so that's the reason why there is a category for each.
When a specific exercise is not available within the exercises we offer, we suggest to use "Workout" (which is a generic catch-all for other types of exercise). Once you finish the activity, you can rename the activity to desired exercise/activity. Please note that the amount of calories burned vary from the exercise you're performing and due to the heart rate tracked by your Versa 4.
Note that the information to enter will change depending on the nature of the exercise. To give you an example, if you change from "Workout" to "Run", it won't remove the calories but will add distance as the main stat to be displayed, this happen depending of the activity you are categorizing. However, your the data already tracked will be still counted for your daily totals.
For more information about how to do so, see How do I add, edit, or delete Fitbit data and activities?
Thank you for the response. When I got to edit exercise details on the app all I change there is the start and stop time. The name is grayed out.
There is a way to modify the activity category but the list is limited to 5 alternatives and nowhere to add a new category.
