12-08-2022
15:01
03:17
12-08-2022
15:01
03:17
Hello, I would like to know: when the timer ends, does the vibration continue until you stop it? Or it just vibrates once? Thank you!
Best Answer12-08-2022 18:57
12-08-2022 18:57
Continue...
Best Answer12-08-2022 20:23
12-08-2022 20:23
Hi @Bonjour123 - as @Franxoxo says, it continues, but you may find a blank display, in which case it might seem it is vibrating for no apparent reason or there is a fault but if you push the button to wake the display you can then see and stop the timer vibrating.
