07-13-2023 21:24
07-13-2023 21:24
I just went for a run with my Versa 4 (did not bring my phone), now when I look at the activity in the app or on the fitbit dashboard in browser from a computer, I do not get a map, no splits, no elevation. It did sync heart rate, calories, and some basic info like steps, distance, time, etc. Can I get it to sync the map, or is the data just lost now?
07-13-2023 23:35
07-13-2023 23:35
There are two possibilities. GPS was disabled in Run settings (Exercise app, Run, swipe up for settings, see if GPS is on) or just didn't connect through entire run. In both cases, the map won't be there and you can't recover it.
07-14-2023 07:42
07-14-2023 07:42
During the run, my tracker was showing accurate pace and distance, so it seems that GPS was enabled and connected
07-14-2023 07:50
07-14-2023 07:50
@vbaratham distance and pace may not be coming from GPS but be based on inertial sensors and it's not an indication of GPS connection.
07-14-2023 09:16 - edited 07-14-2023 09:18
Hello @vbaratham and welcome to the Community. I agree with @Triletics. It sounds like your GPS didn't connect or you don't have it On for your Run shortcut. When you choose a GPS enabled activity and the GPS is on, you first see the words 'GPS connecting' with an animated arrow at the top of the screen. Your Versa 4 vibrates and the message changes to 'GPS connected'. If you didn't see this on your screen, please do the following to make sure the GPS is on.
Your Fitbit uses a steps x stride length for distance when the GPS is off. You get the calculated pace and other stats. In addition, I recommend that you wait until the GPS connects before you tap on that Start arrow and start your run. It can take several minutes for the GPS to connect.
Laurie | Maryland
07-14-2023 10:46
07-14-2023 10:46
I’ve had trouble lately getting my Versa 4 to connect to GPS…and dropping the connection…found there is a link with the increase in aurora borealis activity… see this article…https://www.swpc.noaa.gov/impacts/space-weather-and-gps-systems
07-16-2023 23:12 - edited 07-16-2023 23:13
@LZeeW @Triletics Thanks for the suggestions. I went for another run, confirmed the GPS had connected before I started, and still didn't get a map when the activity was synced. Anything else that might get it working? Everything was fine for a few months until my two most recent runs.
