03-02-2024 04:56
03-02-2024 04:56
My Versa 4 stopped calculating a sleep score recently and in turn does not calculate a readiness score. It tracks sleep stages and heart rate, but no sleep score. See picture.
03-02-2024 10:47
03-02-2024 10:47
Hi @Rickswife. Welcome to the community forums.
Thank you for taking the time to share the difficulties about the sleep score that you are experiencing and for the screenshot.
In case the situation is related to the Fitbit app, please try the following:
Keep in mind that you must see sleep stages in order to see a sleep score. There are a few scenarios where you might see your sleep pattern (which shows your time asleep, restless, and awake) instead of sleep stages:
If you see sleep stages but don’t see a sleep score, please note that it may take a few minutes for your sleep score to appear. In addition, for better results please try to let the device detect that you're awake or asleep by itself rather than doing it manually and make sure to keep the Fitbit app and the devices' firmware updated to the latest version available.
The Versa 4 may need some days to collect some information (particularly regarding to heart rate) and provide sleep score, sleep stages and other data. Make sure that you've also tried the restart procedure described here and check if you continue to experience the same problem.
