02-16-2023
03:47
03:55
02-16-2023
03:47
03:55
Can't get notifications on my Fitbit Versa 4 to work properly. It says the service is not running and the phone needs a reboot, which doesn't help. Have checked the permissions in the phone and that there is no battery saver mode on. It's not on sleep or do not disturb mode. Have an Android phone. Has anyone had the same problem and solved it? A notification pops up every now and then, but just a short while later it stops working again. Test notifications work. I have gone through the troubleshooting guide.
02-16-2023 04:00 - edited 03-09-2024 07:54
Hi there, @TeresiaW. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 4 before reaching out.
I'd like to provide the following steps that actually work for Huawei users, but even if you have a different brand I'd still suggest giving them a try:
Note that you may see a message on your phone related to power consumption and apps scanning in the background. If you follow the steps in this message, the Fitbit app can’t run in the background and certain features may not work properly. Repeat the steps above to enable the Fitbit app to run in the background.
Best Answer02-16-2023 04:00 - edited 03-09-2024 07:54
Best Answer02-16-2023 10:20
02-16-2023 10:20
Thank you very much! Found auto-launch and now it been working all afternoon!
02-16-2023 10:29 - edited 07-12-2023 06:24
@TeresiaW Awesome! I'm glad to hear that the issue is solved now.
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members.
