05-08-2023
03:42
04:42
05-08-2023
03:42
04:42
Have followed all the tips and troubleshooting on the help site without success. Have reinstalled the app, reset the device and still no success.
Using an iPhone which is current with software and the app is updated to current version.
Weirdly, calls will come through fine, but it will not receive notifications from texts or calendar or third party apps.
Grateful for any suggestions that are not contained on the help pages for Fitbit.
Best Answer05-08-2023 04:41 - edited 09-05-2023 04:32
Hi there, @AppleseedER. Welcome to the Fitbit Community Forums. Thanks for trying to troubleshoot the issue with your Versa 4 before reaching out.
In addition to the steps you've done, please try the following in the order listed:
With the steps above, what I want you to do is to pair your Versa 4 first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
Best Answer05-10-2023 02:16
05-10-2023 02:16
Thanks @MarreFitbit but this did not work. Can receive calls but no text or calendar notifications. Have reinstalled the app, re-set up and removed all other Bluetooth devices too.
What other suggestions do you have?
This seems like a fault with the Fitbit - it shouldn’t be this difficult to connect it.
05-10-2023 04:34 - edited 05-28-2023 05:27
@AppleseedER Thanks for getting back and the details provided.
The text messages not coming through are your iMessages? If so, please try toggling the iMessage setting; general > Messages > iMessage and verify the "Show Previews" is on "Always". As for the calendar notifications, are they also the default calendar app on your iPhone? If so, do the same as the iMessages.
Hope this does the trick!
Best Answer05-21-2023 00:24
05-21-2023 00:24
Hi @MarreFitbit these settings are set and haven’t changed things - it’s iMessages and apple calendar. I have the same problem even after I’ve changed phones today to a brand new iPhone 14. I wouldn’t mark this as answered, still have the same problem. Not sure what else I can do other than return the Fitbit?
