01-20-2023
15:41
07:45
01-20-2023
15:41
07:45
Previously I tapped the face and I received the time and steps. Now I have to press the button on the side to get time and steps. Can I go back to tapping the face for time and steps? Thanks
23:11
13:46
01-20-2023
23:11
13:46
Hi @bondman3050 - even better, pull down the watch face and turn off all the icons, except brightness [which may or may not work].
That way when you look at the watch you will see the information without button press or tap.
If the displays goes off while you are looking at it a touch of the screen brings it on again, if it's been off a while then a double tap or button press or lower and raise your wrist will bring it on again.
