02-19-2024
14:44
06:39
CrisVillaFitbit
02-19-2024
14:44
06:39
CrisVillaFitbit
I switched from Versa 3 to 4 today. The new watch shows my steps correctly. The app shows my stats from Versa 3 up to the time I moved over and is not registering what the watch says. Any suggestions!
Moderator edit: edited title to clarity.
Best Answer02-19-2024 21:33
02-19-2024 21:33
Hi @Laurie655 - this can be a problem with the new V4 Fitbit App which has problems syncing and can lose connection.
Once you get it syncing properly the information should show but unlike the older app you may have to manually sync it to get the current information in the app.
You may need to toggle Bluetooth off/on, restart the watch, restart the phone, or even logout/login of the app to get it to fully sync.
02-20-2024 06:42
02-20-2024 06:42
Thank you so much for the insight, @Guy_. And welcome back to the community, @Laurie655, I'm glad to see you here once again.
My best recommendation would be for you to restart your Versa 4 and make you sure you're wearing it correctly, since this can impact the Versa 4 from getting information.
Let me know how it goes once you've done this, please.
Best Answer02-20-2024 11:50
02-20-2024 11:50
Best Answer02-20-2024 19:41
02-20-2024 19:41
