12-18-2024
00:40
07:40
DavidFitbit
12-18-2024
00:40
07:40
DavidFitbit
My versa 4 is just under 2 years old and has started crashing randomly. It's fully charged and works fine but then suddenly switches off and won't reboot until I put it back on charge. Is there a fix? Or is it at the end of it's life? Seems a bit short for it to last less than 2 years
12-18-2024 07:37 - edited 12-19-2024 08:37
Hi @WitchyMamma. Welcome to the Fitbit Community! It's great to have you here!
Let me help you with your Versa 2 that is crashing randomly.
That's actually an akward behavior. Have you tried to restart your Versa 4 ? If not, try it: Press and hold the button for 10 seconds until the Fitbit logo appears on the screen, and then release the button.
If the issue persists, check the level of the battery when this random crash arrives. You can see this in the app by syncing right after you put it back on charge. I appreciate your time in this process.
I hope these tips will be helpful for you. Have a great day!
12-19-2024
08:14
20:04
EstuardoFitbit
12-19-2024
08:14
20:04
EstuardoFitbit
I have done a factory reset, i have rebooted, and I have change the clock face. I got my versa 4 5 weeks ago and its shut down 3 times in the past week. Why isn’t fitbit addressing this? According to the forum, Facebook groups, and youtube, this is happening a lot.
How do we fix it, for good? This morning I woke and my firbit was off, which means my sleep stats are off, and my stress management score will be off? I pay a premium membership and have been with Fitbit since 2017. Never had these issues with older models. What’s happening?
12-19-2024 08:47 - edited 12-19-2024 08:47
Hi @JayL7777, thank you for your response and for the troubleshooting steps you have tried.
If you have already performed a factory reset to no avail, i recommend that you contact our support team for further assistance.
They count with appropriate resources to provide you with the assist your case need. I appreciate your time in this process.
Have a great day!
