08-16-2024 14:38
08-16-2024 14:38
I've had my fitbit versa for less than 6 months and the GPS seems to have stopped working. Any suggestions for how to fix it?
Best Answer08-17-2024 12:24
08-17-2024 12:24
Welcome to the forums @Reb1234.
Thank you for providing the details regarding your Versa 4. Sorry to know that you are having difficulties with GPS.
Versa 4 uses dynamic GPS that is automatically used whenever your phone is within Bluetooth reach while doing an appropriate exercise. All details can be found here How do I use GPS on my Fitbit device?
If GPS signal disconnects, your phone or Fitbit device continues to search for a signal. Note: If you previously turned off GPS for an exercise, turn it back on before you start the activity.
Nevertheless, if your device can’t connect to GPS satellites, try these tips:
In addition, please make sure that your Fitbit app is up to date: How do I use my Fitbit app. Also, that your Versa 4 is up-to-date. For more information, see How do I update my Fitbit device?
Best Answer08-21-2024 18:18
08-21-2024 18:18
Thanks for your help. I tried the above an it doesn't make a difference. What options do I have to return this? Who can I contact?
