09-15-2023 13:54 - edited 09-15-2023 14:38
I just noticed that the colorful face of Paths Standard on my Versa 4 fades to black and white. If I push the button, it will bring the face to the regular colored Paths Standard and in a few seconds will fade to black and white date and time. I have restarted my Versa 4 to see if that was a problem, but no. What is going on? Is this on your side or a problem with my Versa 4?
***Update: I have the Paths Standard (full color now) back on my Versa 4. Not sure what was going on, but I shut it down and started it back up two times before it was back to normal. Guess I'll see how long it stays 'normal' until it acts up again. So weird.
Best Answer09-15-2023 23:59
09-15-2023 23:59
Hi @Deshal - if you pull down on the watch face to get to Quick Settings ensure all icons are off.
You probably had the Always On icon enabled which tries to save battery instead of blanking the screen [so you get a simplified version but it still uses more battery than when it goes blank]
