02-21-2026
06:58
08:21
HorareyFitbit
02-21-2026
06:58
08:21
HorareyFitbit
Hi all,
my versa 4 worked just fine until I forgot to take it off before I applied spray sunscreen on my arm.
if I hold the main button down I feel a short vibration but it won’t turn off or show anything on the screen.
Hi @Walkingbudd, welcome to our Community, is nice to have you here!
As a first recommendation I can suggest you to try to clean your Versa 4 like indicated in this article: How do I clean my Fitbit device?
If that doesn´t improve your situation you can contact our Support team to look deeper in your situation. You can follow the next link where you can select how you want to contact support. Support.
