04-09-2024 02:34
04-09-2024 02:34
I have a brand new Vera 4 purchased mainly for stats when running. After a run the stats sometimes show splits per kilometer (which I need) and at other times it does not show the splits. Does anyone know why this is? I guess its something to do with settings but I cannot figure it out.
Best Answer04-09-2024 09:19
04-09-2024 09:19
@jimsut16 Hey there, when you start your run, are you always starting it from the device or do you allow it to pick the run up on its own?
Best Answer04-09-2024 10:07
04-09-2024 10:07
Best Answer04-10-2024 06:47
04-10-2024 06:47
@jimsut16 I assume this is what you are looking for? And you aren’t seeing this consistently with all GPS-connected runs?
Best Answer04-10-2024 10:40
04-10-2024 10:40
Hi Heather,
Yes, that is correct.
Thanks, Jim.
Best Answer04-10-2024 10:56
04-10-2024 10:56
Hi Jim,
My name is Kevin and I have the exact same problem. I sent simply can’t bring up the split times. Have you found out additional? Thanks!
Best Answer04-10-2024 11:03
04-10-2024 11:03
04-11-2024 09:55
04-11-2024 09:55
@jimsut16 I find the exercise details really slow to populate. I just pulled up a walk and it took at least 30 seconds for those splits to show. Have you tried waiting 30-45 seconds to see if it will eventually load in the exercise details?
Best Answer04-13-2024 02:13
04-13-2024 02:13
Hi Heather,
Yes,
I have tried the delay but still the same.
Thanks, Jim.
Best Answer04-13-2024 04:27
04-13-2024 04:27
@jimsut16 That is very weird. I am getting the splits consistently on all my outdoor walks/runs. What phone/OS are you using? Is your Fitbit app up-to-date?
Best Answer04-13-2024 04:33 - edited 04-13-2024 04:34
@jimsut16 One other thing to check... when the Versa 4 comes in the box, I believe the GPS is turned off for activities like Run or Walk, when you tap on the Run exercise on your watch, swipe up and scroll to the bottom where you'll see GPS. Make sure that is switched on.
Best Answer04-13-2024 04:43
04-13-2024 04:43
@jimsut16 One last thing to try... you can enable laps to your walk or run, however, I am getting the splits without having this feature turned on. Here are the instructions to turn on auto lap counting, perhaps this will help, but like I said, mine works for me without it, but I'm desperate to find you a solution!
Best Answer04-14-2024 10:20
04-14-2024 10:20
Thanks Heather.
The splits have shown on my most recent runs. I have a feeling it may be something to do with how I start the exercise on the device. That's something you had mentioned to me previously. I'll try to keep this consistent and see how it goes. I'll keep you updated.
Thanks again for your help.
Jim.
