06-13-2025
09:33
10:40
DavidFitbit
06-13-2025
09:33
10:40
DavidFitbit
Keep hitting the install button, it looks like it works and then goes right back and shows the install button again.
It has the two minimum tiles on there but it will not let me install any of the others.
Restarted both the phone and the versa.
Did a force stop on the app and opened it again. Uninstalled and reinstalled all the same thing.
Moderators action: Updated subject for clarity
07-04-2025
07:48
17:16
EstuardoFitbit
07-04-2025
07:48
17:16
EstuardoFitbit
I am having trouble with my fitbit smartwatch and the Fitbit app it keep saying that it looking for Fitbit and it wont work for my device
07-05-2025 22:18
07-05-2025 22:18
First time I've ever commented on anything on here but wanted to thank you for finding the solution to this. It's been driving me crazy for days now, I'd have torn my hair out if life hadn't already done it for me.
07-09-2025 13:07
07-09-2025 13:07
Mine was doing the same thing and I was sooo irritated. I did all the things you did to try and fix it and it didn't work. What did work:
Go to apps on your Fitbit app
Click on Timer, Uninstall
Then search again for Timer in the apps and it will give you 2 options, the regular fitbit timer and the timer tile. Select the timer tile. This should do it!
07-09-2025 14:17
07-09-2025 14:17
Thank you for another workaround. It is crazy that we have to do this at all 😕
07-11-2025 09:39
07-11-2025 09:39
This fixes everything...ordering tiles, customizing clock faces, removing or installing tiles. There is nothing in any of the documentation I've seen that mentions holding down the clock face and swiping right to Open Gallery. Apparently, the Fitbit technicians don't know about it either. Thanks!!
