10-22-2025
07:41
08:11
10-22-2025
07:41
08:11
I purchased a Fitbit Versa 4 on 21 Oct 2025. Per the instructions, I fully charged it to 100% when I set it up. In less than 24 the Versa 4 drained to 6% and I had to recharge it. The documentation says it is supposed to last 6 days on a charge. Is there something in the setup that can prematurely drain the Versa 4?
Best Answer10-22-2025 08:15
10-22-2025 08:15
Hi there, @shauncoleman999. It's nice to see you around the Fitbit Community Forums. Thanks for bringing this to my attention. I'm sorry to hear that the battery of your Versa 4 is draining quickly. I understand your concern, I will do my best to help you with this!
As a first approach, I'd recommend making sure that your phone's software version is updated. For more information, refer to Check & update your Android version or Update your iPhone or iPad
If you haven't done so yet, please try all tips and recommendations provided here Can I extend my Fitbit device's battery life?
10-22-2025 08:15
