Versa 4 blank screen
Spoiler
My Fitbit versa4 is showing black screen though when pressed the button it vibrates but nothing can be seen not even the logo
Also it is not syncing with the mobile app
3 REPLIES 3
please contact support. try to charge it and see if it vibrates, if so its a screen/hardware issue.
Hi there, @Drjasmine. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention. I'm sorry to hear that your Versa 4 screen is blank. I understand your concern, we're here to help you!
If you haven't done so yet, please try the steps below:
  1. From the Today tab in the Fitbit app, tap the devices icon at the top-left corner.
  2. Tap your Fitbit device image.
  3. Near the bottom of the page, tap Sync Now.
If the above doesn't work, please restart your Fitbit device as suggested here How do I restart my Fitbit device? Note: Restarting the device doesn’t delete any data. If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
@humanbeing19823 Thanks for helping out!
Hi ....
Tried everything....but to no avail
It had switched on for some time and then tried to do factory reset.....that happened,updated the software and then again it went blank....
What to do.....
