02-09-2025
18:30
03:57
02-09-2025
18:30
03:57
My Versa 4 screen is totally black, it vibrates but does not reset or sync. I keep it on charge for a few days but still nothing. It’s one year old and I can’t even reset it.
02-10-2025 04:06
02-10-2025 04:06
Hi there, @Renatafarinha. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that the screen of your Versa 4 is still blank. I will do my best to help you with this!
Have you tried manually syncing your Versa 4? If you haven't done so yet, please try the steps below:
If the above doesn't work, please restart your Fitbit device once again as suggested here How do I restart my Fitbit device? Note: Restarting the device doesn’t delete any data. If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
02-10-2025 23:53
02-10-2025 23:53
Best Answer02-11-2025 03:45
02-11-2025 03:45
@Renatafarinha Thanks for trying the steps I recommended. I understand how you must be feeling and how important your Fitbit device is to you.
As our last resort, I'd recommend a factory reset. Important: Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
With the above being said, press and hold the button for about 8 seconds until the screen turns off and vibrates. When you feel the vibration, release the button, then immediately press and hold the button again. Wait for the Fitbit logo to appear, then as soon as the logo disappears, release the button, then press and hold the button again. When you feel the vibration, release the button, then wait for the watch to complete the factory reset.
02-11-2025 07:34
02-11-2025 07:34
Have you recently updated the software on your Fitbit? Mine also did this and could be the same issue many of us community members are experiencing but Fitbit aren’t resolving or owning up to causing. @MarreFitbit Perhaps you could escalate this issue to someone more senior as there seems to be a trend appearing.
02-11-2025 10:23
02-11-2025 10:23
Best Answer02-11-2025 10:26
02-11-2025 10:26
Best Answer02-18-2025 19:02
02-18-2025 19:02
Hi,
I’ve tried all of your suggestions and nothing seems to be working. I think the screen must be broken. What can I do if the screen is broken? Please advise
