02-07-2023 12:39
02-07-2023 12:39
On my Versa 4, the brightness doesn't change even if I toggle through the different levels.
I have checked sleep mode and it's off.
Whenever I toggle between the modes, it just sets to that brightness for half a second and reverts to its original brightness.
I have restarted the phone multiple times.
I have updated firmware.
On bright sunny days, the brightness is just dismal and these bugs are making it hard to use it.
02-07-2023 12:41
02-07-2023 12:41
I meant "restarted the device".
02-07-2023
20:50
11:41
02-07-2023
20:50
11:41
Hi @SrinidhiMurthy - yes it seems to have a mind of if its own.
The Quick Settings indicator may not reflect the same setting as in the watch Settings, Display menu or it may change between switching views.
Brightness issue seems to be a bug.
Turning on Sleep does seem to set it to Dim but with the brightness icon On, whereas in previous models it was off (to show Dim) during sleep.
Also note the wrist wake icon is Off when wrist wrist wake is active whereas on previous models it was On.
02-07-2023 23:38
02-07-2023 23:38
Right. These are very pesky set of settings and counter-intuitive. Not sure if this is acknowledged by Fitbit and a fix is being worked upon.
02-07-2023
23:46
11:41
02-07-2023
23:46
11:41
@SrinidhiMurthy - you are quite right, but Fitbit chose to do it that way so most likely it will not change.
The brightness bug might get fixed when they decide to address it. When/if that will be is unknown.
