05-16-2024 17:49
05-16-2024 17:49
Every time I start a run, my watch buzzed up to six times. It’s incredibly distracting because I don’t know what it’s about and don’t know how to make it stop. I have do not disturb mode on (although I don’t allow texts or calls be sent to my watch). Usually one buzz is for GPS and that’s fine but six!?
05-16-2024 21:41
05-16-2024 21:41
Hi @Jaxrunner - your post is moved here even though marked Versa (as it doesn't have a GPS and title shows versa 4 which does).
Did you try restarting the watch by holding the watch button for 10 seconds till it blanks or vibrates and wait for the logo to appear and for it to start.
Best Answer05-17-2024 03:43
05-17-2024 03:43
Note on tags, the post wouldn’t let me tag Versa 4, only every other version of Versa. Yes I’ve restarted it several times.
Best Answer05-17-2024 04:02
05-17-2024 04:02
@Jaxrunner - there are various options to choose before starting a run. Press the button, select exercise, select run, then swipe up to see them.
Try different settings, also with GPS off.
Note: Versa 4 is not an option in the other smart watches forum as the watch has it's own forum.
