05-15-2025
17:42
03:48
05-15-2025
17:42
03:48
I've had my versa 4 for about 2 years and haven't had any issues up until recently. The screen is extremely dim and the display looks like weird. I haven't done anything to it to make it show up like that , I have followed all of the guides possible including unpairing the device and removing it from the app but now I can't even re-add it. When I go to set it up, it will say that it's not recognized. Is there a way to fix this or is my device gone?
Hi there, @Spicychick3n. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that the screen of your Versa 4 is still blank and that it won't connect now. I understand your concern, I will do my best to help you with this!
Since you've unpaired your Versa 4, I'd like to make sure you've done the following in the order listed so you can properly add it back:
If the screen of your Versa 4 is still too dim after pairing it back, make sure that the brightness settings are not set to "Dim". If this doesn't describe your issue, please try the following:
If the above doesn't work, please restart your Fitbit device once again. If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
