My experience with Versa 4
I have had pretty good luck with Fitbit trackers and have stayed loyal... until I purchased the Versa 4 to replace my Versa 2.  This version is plain worthless.  The thing has to be charged daily, yes, I have the clock/display only appearing if I push the side button and all notifications (email/text/calls) turned off... and it still won't hold a charge for more than a day.  It rarely syncs with the app unless I force it too.  It doesn't count all steps or my SpO2 like it should be.  I could go on.
This was the biggest waste of $200!  I would NOT recommend it to anyone!  I'm thinking my loyalty to Fitbit has run it's course and it's time to move on.
Update: In addition, I have only had the Versa 4 for less than 5 months.
3 REPLIES 3
Hi there @SRunzicker!
It's great to see that you've visited the Fitbit Community!
Thank you so much for reporting this situation. I'm sorry to hear that the battery of your Versa 4 doesn't last as long as it should and understand how frustrating this is.
Have you already tried to follow all the troubleshooting steps from this article "Can I extend my Fitbit device's battery life? "?
If the situation with the battery short life continues, please try to contact support.
I have researched everything to do with my Fitbit Versa 4 battery, both on the Fitbit forum and on the internet.  The battery might work ok for a couple days, but then it starts acting up all over again and I might get 8 hours out of it before it is dead.  Long and short... I still would NOT recommend Fitbit Versa 4 to anyone!!  It is a waste of my time and money.
By the way... I re-corrected my posting title as someone felt the need to change it to "soften" my words.  The battery on a Versa 4 is junk.  People need to know what they are "buying".
Dear Fatima ...
We tried everything... We need actual solution or a replacement of the device!
