10-09-2024
04:18
06:45
10-09-2024
04:18
06:45
My versa 4 is not recording any sleep , it has recorded it all year but last week nothing I have also lost all of my steps data for last 9 months
Best Answer10-12-2024 13:25
10-12-2024 13:25
Hi @Naz76. Welcome to the community forums.
Thank you for providing the details regarding this difficulty experienced with your Versa 4.
Please, make sure that you are using the latest version of the Fitbit app.
Keep in mind that you must see sleep stages in order to see a sleep score. There are a few scenarios where you might see your sleep pattern (which shows your time asleep, restless, and awake) instead of sleep stages:
If you see sleep stages but don’t see a sleep score, please note that it may take a few minutes for your sleep score to appear. In addition, for better results please try to let the device detect that you're awake or asleep by itself rather than doing it manually and make sure to keep the Fitbit app and the devices' firmware updated to the latest version available.
The Versa 4 may need some days to collect some information (particularly regarding to heart rate) and provide sleep score, sleep stages and other data. Make sure that you've also tried the restart procedure described here and check if you continue to experience the same problem.In case the problem is related to the Fitbit app, please try the following as well:
