08-03-2025
13:39
04:34
08-03-2025
13:39
04:34
Hello All
I got versa 4 smart watch for my son but he got iphone 7. fitbit app not working on iphone 7. Is there any solution for him to use Fitbit versa 4 watch and pair using his old phone or just use web browser to sync all.
Best Answer08-07-2025 06:20
08-07-2025 06:20
@Vish30 He doesn't need the newest model, if that isn't in your budget. Just one that will supported for a while. For example, I use an iPhone 13, which should be supported for 5 more years,
Laurie | Maryland
08-03-2025 13:58
08-03-2025 13:58
Hi @Vish30 The Fitbit app requires iOS 16.4 or higher. The iPhone 7 can’t upgrade beyond iOS 15. There is no web dashboard for syncing. There is no workaround.
Just to be complete, because you don’t mention your son’s age. A child must be 13 and older in the US and older in some other countries. The Versa 4 uses a web based system. It isn’t compliant with several international children’s privacy protection laws.
Laurie | Maryland
08-07-2025 05:38
08-07-2025 05:38
Hi @LZeeW , many thanks for your reply. Yes he is 14. I have to get some other phone for him 😞
08-07-2025 06:20
08-07-2025 06:20
Laurie | Maryland
08-07-2025 06:53
08-07-2025 06:53
Thanks @LZeeW Yes my budget is not for top model. I will buy iphone 13 to replace iphone 7 or some android models that is compatible
Best Answer08-07-2025 08:13
08-07-2025 08:13
@Vish30 You don't need a top of the line Android model, either. An Android phone must support Android 11 or higher. If you are an iPhone family, there are practical reasons to stay with iPhone.
Laurie | Maryland
