07-30-2024
06:11
08:36
07-30-2024
06:11
08:36
At the beginning of every run, my Fitbit buzzes about 4-6 times. It's super annoying because there's a few seconds between each and you don't know when it'll stop. I have notifications off (so no texts or calls), every time I look down, it's not giving me any sort of notification. I am using the GPS function. I've tried to turn off everything possible. It's annoying but I get over it. But the other day I had been running for about 4 miles when it started buzzing, distracting me and showed nothing new on the screen beside my workout.
Any suggestions? I'm about ready to take it off because it's so annoying to be distracting when I need it - during a run.
07-30-2024 08:45
07-30-2024 08:45
@Jaxrunner This issue seems to be related to the dynamic GPS. I never had this buzzing when my Sense 2 only had built in GPS. I noticed it when dynamic GPS got added. Fitbit just started rolling out a firmware update , but I haven't received it yet. The notes say this update is supposed to fix an issue with the GPS connection. I have my fingers crossed, because I gave up on GPS tracking and went old school, just using steps x stride length.
Laurie | Maryland
07-30-2024 08:45 - edited 07-30-2024 08:46
Hi there, @Jaxrunner. It's nice to see you around the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that your Versa 4 keeps vibrating during your runs. I understand your concern, I will do my best to help you with this!
Have you checked if this vibration comes from your active zone minutes? When using the Exercise app, your watch notifies you a few moments after you enter a different heart-rate zone. The number of times your device buzzes indicates which zone you’re in:
Number of Buzzes | Heart-Rate Zone |
1 buzz | Fat burn zone |
2 buzzes | Cardio zone |
3 buzzes | Peak zone |
To turn notifications on or off, please follow the steps below:
For your weekly active zone minutes notifications:
07-30-2024 08:45
07-30-2024 08:45
Laurie | Maryland
07-30-2024 08:54
07-30-2024 08:54
Hi there!
Yes, I have confirmed that heart rate zones is turned off so this is not the root cause. Goal reminders is also turned off.
07-30-2024 08:55
07-30-2024 08:55
This checks out. I had a Versa 2 for several years and it never buzzed like this.
07-30-2024 09:38
07-30-2024 09:38
I'm having this too, and it's SO frustrating! I have zone notifications turned off (for every type of exercise) and I even set a "custom heart rate zone" because I saw that if you have a custom zone, you won't get notifications when you change between zones during exercise. I get a bunch of notifications at the start of my run as well, and then also periodically get them throughout - sometimes a bunch all at once, and sometimes just at random. I have no other notifications set up but am also using GPS. I really hope there's a solution, I have started just wearing my fitbit in my pocket when I run because it's so distracting.
07-30-2024 13:41
07-30-2024 13:41
@MarreFitbit I can assure you that these vibrations have nothing to do with active zone minutes. All of those notifications are off.
Laurie | Maryland
08-08-2024 05:01
08-08-2024 05:01
I am having the same issue! It appears to be from the GPS connection in my opinion. The Versa 3 had an option to get vibrations when the GPS connected and when the connection dropped, however, I could find the feature and turned it off with no problems. I walk in an area where the GPS connection comes and goes more on some days than others. I end up getting dozens of vibrations, if not more during my walk many days, and it is beyond frustrating. Even when I turn all notifications off, I still get the vibrations. I can't turn notifications off because then when it sends the "Do you want to end this exercise off?" If you don't respond no, it stops tracking the exercise.
08-24-2024 18:47
08-24-2024 18:47
Turning the GPS off indeed stops it from vibrating uncontrollably, but that's not a solution. Product developers need to address this.
09-05-2024 06:26
09-05-2024 06:26
I have the same exact problem.. Turned off all notifications in the Run app, but still get the random buzzing the whole time. The only way to stop it is to turn of GPS tracking, but I want the tracking on so I can map my run. FitBit needs to fix this ASAP, allow an option to turn off GPS connection notifications, or allow the watch to use the attached phone's GPS.
09-10-2024 08:24
09-10-2024 08:24
Hi, any other updates or solutions to this? I also can confirm all of my heart rate notifications are turned off and I am still experiencing this issue. It’s getting to the point that GPS is making my fitbit unusable for runs, and that kind of defeats the purpose of having one.
09-17-2024 03:57
09-17-2024 03:57
This question has an answer but no solution. Any updates from Fitbit?
09-18-2024 17:56
09-18-2024 17:56
I have the same issue with the sporadic vibrating when using GPS on the Versa 4. All notifications are turned off. It’s extremely distracting and frustrating. This is my 4th Fitbit and I’ve never encountered this before.
10-01-2024 18:06
10-01-2024 18:06
Is there a way to turn off the "Do you want to end this exercise?" Prompt? It comes on in the middle of an exercise, such as walking or running, and because I don't always see it will just end my exercise and I'm left with no data.
10-01-2024 19:41
10-01-2024 19:41
Is there a specific notification that I can turn on so I don't receive the "Do you want to end this exercise" message?
10-04-2024 08:49
10-04-2024 08:49
10-21-2024 05:36
10-21-2024 05:36
A new all time low for Fitbit. FORTY SEVEN BUZZES in a 25 minute timeframe. Sometimes groups of 6, groups 3, individual. Incredibly distracting and dangerous when I’m trying to run. I’ll be asking for a full refund on this product. Trash.
10-21-2024 07:46
10-21-2024 07:46
Fitbit could we get an update on this? I am having the same issues, 35+ vibrations during a 2.5 mile run last week. I had been SO excited for Versa to get GPS and it's basically unusable. I live in a city and there shouldn't be issues with GPS connection like this. I also don't understand why there's not an option to turn this off when it's an incessant vibration that you can't do anything about.
