08-03-2023
04:43
08:36
EstuardoFitbit
08-03-2023
04:43
08:36
EstuardoFitbit
Why is my Versa 4 not charging? There’s always something to worry about.
Moderator Edit: Clarified Subject
08-03-2023 08:36 - edited 08-03-2023 08:37
It's nice to see you here in the community again @Ninjagranny. I'm sorry you're having trouble charging your Fitbit Versa 4.
I would like to recommend some steps to get your device back on track, pleas do the next:
As a first step I would like you to try cleaning the charging contacts on the back of the device using a toothbrush and some fresh water.
I also need you to clean the pins that are on the charging cable, you will need to use a cotton swab and some rubbing alcohol, making sure no pieces of the swab are left on the pins.
Lastly, you'll need to connect it to another USB port or a UL-certified USB wall charger.
Best Answer08-03-2023 09:48
08-03-2023 09:48
Best Answer08-03-2023 10:28
08-03-2023 10:28
@Ninjagranny No worries, I'm really glad to hear you sorted this out. Please do not hesitate to keep sharing your experience with us, we are here to help!
