01-12-2025
14:08
08:02
FatimaFitbit
01-12-2025
14:08
08:02
FatimaFitbit
Help!
Recently my versa 4 would not turn on when I pressed the button, it would just vibrate. I would then hold down the button and a black screen with dots would appear, and after so nothing. If I held it down again the screen would appear again and alternate with a blue screen with black dots until a black screen with a Red Cross would appear. It would still not turn on. The first time this happened I charged it, despite it being at 80%, and it was fine.
This was yesterday, and today the same thing happened again. However this time I have been unable to charge it due to being away from home, and now when I press down the button nothing happens, the screen with the dots doesn’t even appear.
I tried to sync it to my app but that did not work.
Also, recently the battery hasn’t been the best, draining quicker than normal.
The watch is less than a year old and hasn’t been in any water/had any damage!
Thanks for any help!
01-21-2025 08:01
01-21-2025 08:01
Hi there @kmordue! A warm welcome to the Fitbit Community!
Thank you so much for letting us know about this situation and for all your efforts.
I suggest you try to do a manual factory reset:
01-23-2025 05:03
01-23-2025 05:03
Hello,
Unfortunately it is still not working.
I've followed these steps (I tried multiple times). It came up with a loading bar at one point, but then went black again. Then when I pressed the button the button nothing happened until I held down the button and the logo came up again.
01-24-2025 05:27
01-24-2025 05:27
Hi @kmordue!
Thank you for your answer and for your efforts.
Did you try to follow the troubleshooting steps described in this article Why can't I set up my Fitbit device?
Which phone and Android or iOS version do you have?
Best Answer01-25-2025 01:55
01-25-2025 01:55
Hello,
yes I’ve tried all the steps I could - as the Fitbit itself isn’t turning on it’s not an issue with it connecting to my phone so half of them weren’t really relevant.
I tried resetting while attached to power and still nothing.
I have an iPhone 12 and am on IOS17.6.1
Best Answer01-25-2025 08:18 - edited 01-25-2025 08:19
Hi @kmordue!
Thank you for your answer and all your efforts. I'm sorry that the issue continues.
Since you have tried the steps and your Versa 4 still doesn't work, I need more information from you, which is best shared privately. I am sharing a link to a form for you to fill out here.
This form is for you only, so let me know when you have completed it.
Best Answer01-26-2025 04:49
01-26-2025 04:49
Hello,
I have filled out the form!
Thank you
