04-28-2025
18:08
11:39
04-28-2025
18:08
11:39
Hi, ever since updating my versa 4 the other day I keep having a popup of the symbol of a phone with a slash through it appearing on my watch and have not been getting all my phone notifications on my watch. This happens literally seconds after I sync it if I lock my phone or close the app. I have tried shutting down my fitbit, disconnecting/ removing the watch from my phone and fitbit app, turning on and off my phones bluetooth and powering off my phone and re-pairing the watch and the popup is still appearing. Is this a software issue? How can I fix it?
04-29-2025 09:26 - edited 04-29-2025 09:29
Means no bluetooth connection to phone - could be out of bluetooth range from phone.
04-29-2025 17:55
04-29-2025 17:55
I have checked and confirmed that my phones bluetooth is on and my phone says it is connected to the watch. this happens literally as soon as i close the app on my phone or lock my phone even if it is in my pocket.
04-29-2025 20:42
04-29-2025 20:42
You closed the app - there you have it. If you prefer to turn off the status indicators altogether, see above.
04-30-2025 07:36
04-30-2025 07:36
This hasnt been an issue previously, and I shouldnt have to have my phone open and running the app 24/7 to use my watch. This has only been an issue since this update. Further, your tone comes off quite condescending. Customer support should support the customers, not tear us down.
04-30-2025 09:21
04-30-2025 09:21
A) I am not Customer Support, just a Fitbit user like you, freely volunteering my own time to try to help other users, although I'm sorry if you perceive not appropriately in this case.
B) Yes, the Status Indicators were added in an update. If you don't like them, you are free to turn them off, though the display should go off on its own in a couple of seconds.
C) If you don't like the way the Status Indicators work or were implemented, you can leave your suggestions in the Product Feedback forum.
https://community.fitbit.com/t5/Product-Feedback/idb-p/features
05-04-2025 12:31
05-04-2025 12:31
Mine has been doing this, too. The app is open and my phone is often in my hand when it happens.
05-20-2025 10:32
05-20-2025 10:32
Hi, I've had this problem on and off for years - I would just randomly stop getting text notifications on my Versa 4, even though nothing had changed. Now I also get the little "phone with a slash through it" when it happens so at least I know right away. I've tried everything like you listed, but the only thing that works for me is a factory reset. It's a real pain, but works for me. I started getting the "phone" icon 3 days ago and just spent 30 minutes doing the reset and that has fixed the problem.
05-28-2025 03:37
05-28-2025 03:37
Updated this morning and mine is now doing this too. How do we get in touch with customer service cause this is an issue.
