07-27-2025
00:57
10:01
CrisVillaFitbit
07-27-2025
00:57
10:01
CrisVillaFitbit
Hi, yesterday my versa 4 suddenly stopped working. It now flashes on with the Fitbit sign if I hold the side button for 8 seconds but then turns to a big red X. I have tried forgetting the versa on my app like other posts say. Also disconnected Bluetooth on/off.
my phone now won’t recognise the versa…. Help!
Moderator edit: edited title to clarity.
07-27-2025 10:07
07-27-2025 10:07
Hello and welcome to the Fitbit Community, @Keldog77.
Thanks for letting me know about this situation in regards to the red x showing in your Versa 4, I know how you can feel, I'll do my best to help you.
I also appreciate the steps you followed, my best recommendation for you right now would be to factory reset the Versa 4:
- Press and hold the button for about 8 seconds until the screen turns off and vibrates. When you feel the vibration, release the button, then immediately press and hold the button again.
- Wait for the Fitbit logo to appear, then as soon as the logo disappears, release the button, then press and hold the button again.
- When you feel the vibration, release the button, then wait for the watch to complete the factory reset.
08-01-2025 11:28
08-01-2025 11:28
I also had this same issue. I did this and still didn't fix the problem.
What can I do next?
08-02-2025 17:28
08-02-2025 17:28
Likewise. Same experience. Red X.
08-02-2025 17:31
08-04-2025 14:44
08-04-2025 14:44
Same issue. Followed the recommended steps but issue has not been resolved
08-05-2025 01:05
08-05-2025 01:05
I have the same issue but Factory reset does not work it keep coming back to the screen asking me to select the language. This just happened out of the blue! and my Versa 4 was fully charged earlier in the day so it was over 90%. It does not allow the reset. i push and hold and no vibration until i release the button, then it vibrates once, i press again and same thing.. any ideas?
08-05-2025 07:54
08-05-2025 07:54
I have the exact same issue … and have tried all of the same “fixes” … help!
08-05-2025 13:59
08-05-2025 13:59
I have done all these steps and I still can't get notifications on my versa 4
Best Answer08-05-2025 18:04
08-05-2025 18:04
Guess what? I called Google/FitBit Help Desk. Their only remaining option was to provide me a 35% discount on a new, replacement Versa4 since mine was over a year and thus out of warranty. My new one should be arriving any day. HOWEVER, while waiting I hooked my current Versa4 to ensure it was fully charged. I then got this bright idea to UNINSTALL the FitBit App from my Android, then REINSTALL the App. I then tried another RESET on the Versa4 ... Lo and Behold, they connected and the Versa4 updated, restarted, and is now functioning!!!
08-05-2025 18:05
08-05-2025 18:05
Guess what? I called Google/FitBit Help Desk. Their only remaining option was to provide me a 35% discount on a new, replacement Versa4 since mine was over a year and thus out of warranty. My new one should be arriving any day. HOWEVER, while waiting I hooked my current Versa4 to ensure it was fully charged. I then got this bright idea to UNINSTALL the FitBit App from my Android, then REINSTALL the App. I then tried another RESET on the Versa4 ... , they connected and the Versa4 updated, restarted, and is now functioning!!!
Best Answer08-05-2025 18:11
08-05-2025 18:11
Best Answer08-05-2025 19:44
08-05-2025 19:44
Best Answer08-06-2025 06:21
08-06-2025 06:21
Thank you so much … I just tried that and so far (1 hour) my versa 4 is working beautifully!! THANKS AGAIN!!
Best Answer08-06-2025 09:00
08-06-2025 09:00
This did not work. It is also not recognized on my phone or any bluetooth (incase that helps)
Best Answer08-06-2025 14:17
08-06-2025 14:17
Best Answer08-08-2025 10:21
08-08-2025 10:21
They also offered me the same thing, but I am hesitant to buy another one because of this horrible experience.
I will try this and I hope it works 🙄
I am glad yours is working now👍
Best Answer08-14-2025 14:24
08-14-2025 14:24
