11-16-2022
13:21
14:43
11-16-2022
13:21
14:43
I just got my versa 4 - when I hold the button down for 10 seconds, I get a flashing blue screen 3 times then it goes to a red x and shuts down. When I plug the charger in, it does not show anything on the display. If i hold down the button less than 10 seconds it shows the fitbit logo for about 5 seconds then it turns off. Do I need to return? Any ideas would be appreciated
Best Answer11-16-2022 14:46 - edited 12-18-2023 05:24
Hi there, @steve1328. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 4 before reaching out.
While reading your post I was wondering if you have another Fitbit device linked to your Fitbit account? Note that you can't connect multiple devices that use the Fitbit Gallery to one account. For Fitbit Charge 3, Fitbit Charge 4, Fitbit Charge 5, Fitbit Ionic, Fitbit Inspire series, Fitbit Luxe, Fitbit Sense, and Fitbit Versa series, only connect one of these devices to your account at a time.
If you have any of the Fitbit devices mentioned above linked to your Fitbit account, that might be causing connectivity issues with your Versa 4 and the Fitbit app.
With that said, try the steps below:
If you want to use both Fitbit devices, I recommend creating a separate account for each.
Hope that helps.
Hope that helps.
Best Answer12-10-2022 04:40
12-10-2022 04:40
I have the same problem:
I restarted it, turned on and off my bluetooth and the problem is still occuring. I want to get some help about it. Thanks in advance.
Best Answer01-09-2023 20:47
01-09-2023 20:47
I am having the exact same issue - I just got my versa 4 - when I hold the button down for 10 seconds, I get a flashing blue screen 3 times then it goes to a red x and shuts down. When I plug the charger in, it does not show anything on the display. If i hold down the button less than 10 seconds it shows the fitbit logo for about 5 seconds then it turns off. I also have restarted the device and deleted the app, shut down the bluetooth, and reinstalled the app, etc as the above post by MarreFitbit suggested. Can someone please help and provide further tips.
Thanks!
Best Answer01-10-2023 12:18
01-10-2023 12:18
we sent the watch back and they replaced it
