02-04-2023
18:05
04:35
02-04-2023
18:05
04:35
I have drained My My fitbit Versa 4 battery. After a few days, I charged my fitbit. But it was not turning on completely, it's showing only the fitbit logo. What need I need to get back to it's original position
Best Answer02-07-2023 04:39 - edited 07-03-2023 06:43
Hi there, @Vinay_danda. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 4. @Guy_ Thank you so much for your help!
To solve this issue, please follow the steps below:
If you can't get started with your Versa 4, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
Best Answer02-04-2023 21:09
02-04-2023 21:09
Hi @Vinay_danda - first, once the watch is charged, try a restart, press and hold the button for 12 seconds till it vibrates and the logo appears and it starts after a minute.
If that doesn't happen try removing the Bluetooth entry from the phone, logout of the Fitbit App. Login again and click profile photo, "+ Set up a Device" and replace.
If still no sucess can you chat via the Fitbit App, click profile photo, Help & support, Contact Customer support. They may take you through a factory reset.
