07-14-2023
03:04
11:50
07-14-2023
03:04
11:50
Hi
my versa 4 keeps restarting and a red X appeared during the process. Has been a week.
Hi @Dennisshim316 - did you try turning off the Bluetooth on your phone and then holding the watch button for 10 seconds till it vibrates and the logo appears?
Best AnswerI have the same issue. Did as suggested and it keeps happening. Is there an update to fix this issue? Very annoying and I just literally bought this one a week ago. Have the rose colored one now, same issue with the black one and it completely locked up
Hi @Tazboo492 - if you did the restart and it is still a problem with Bluetooth turned off, try changing to the default clock face, if it is not already and you are able.
If not try chat via the Fitbit App, click profile photo, Help & Support, Contact Customer Support. They may take you through a factory reset.
