08-08-2024
07:51
08:02
08-08-2024
07:51
08:02
i just opened new box yesterday, it was fine around 18 hours that's all
now it's rebooting itself, i tried to hard reset by holding button 10 seconds as guidline, not working
if i hold more than 15 seconds then x mark is appearing
can someone please suggest me, what's the solution in this case
08-08-2024 08:45
08-08-2024 08:45
Hi there, @SunsetRunner. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that your new Versa 4 is stuck on the X. I understand your concern, I will do my best to help you with this!
If you haven't done so yet, please try to manually sync your Versa 4 by tapping your profile picture > your device image > Sync Now. By doing this, a firmware update banner should appear.
If Sync Now doesn’t show an update banner, please tap your profile picture > your device image > Gallery. The app should show a popup to install the missing apps to install the missing apps and recover the device. If the firmware update banner does not show, press and hold the side button for 10 seconds until the Fitbit logo appears on the screen, then release the button. For more information please visit How do I restart my Fitbit device?
If none of the above works, please do a manual factory reset: Press and hold the button for about 8 seconds until the screen turns off and vibrates. When you feel the vibration, release the button, then immediately press and hold the button again. Wait for the Fitbit logo to appear, then as soon as the logo disappears, release the button, then press and hold the button again. When you feel the vibration, release the button, then wait for the watch to complete the factory reset.
02:54
18:09
AndreaFitbit
08-12-2024
02:54
18:09
AndreaFitbit
i did all the above instructions
again the same thing
auto restart/reboot
it worked only in one day
i want a replacement or the other version
if I get lower version also it's okay
but i can't handle this version
08-13-2024 04:47
08-13-2024 04:47
Same problem on my device, that is almost 2 years old. Must be an faulty update, but they wont fix it
08-13-2024 06:17
08-13-2024 06:17
Me too, and bug continuous happens 😞
Best Answer08-13-2024 06:18
08-13-2024 06:18
I agree 👍
Best Answer08-13-2024 06:56
08-13-2024 06:56
i need the replacement
or my money back
this is not one person issue
many are facing the same everywhere
from long long ago people are posting the issues
can't u guys solve this f**king issue from that long
