11-24-2025
16:51
02:31
11-24-2025
16:51
02:31
My second Versa 4 (replacement) and it has stopped working just like the previous one I got. Seems to be the same issue. Any way to fix this? Am I able to get a 3rd replacement? I've only had it for a month..
Hi there, @luisvike09. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention and for the image attached. I'm sorry to hear that your new Versa 4 is stuck on the red X. I understand your concern, I will do my best to help you with this!
Even when the screen seems to be dead and stuck on the red X only, would you mind trying to sync? To do so, please try to manually sync your Versa 4 by tapping your profile picture > your device image > Sync Now. By doing this, a firmware update banner should appear.
If Sync Now doesn’t show an update banner, please tap your profile picture > your device image > Gallery. The app should show a popup to install the missing apps to install the missing apps and recover the device. If the firmware update banner does not show, press and hold the side button for 10 seconds until the Fitbit logo appears on the screen, then release the button. For more information please visit How do I restart my Fitbit device?
If none of the above works, please try a manual factory reset: Press and hold the button for about 8 seconds until the screen turns off and vibrates. When you feel the vibration, release the button, then immediately press and hold the button again. Wait for the Fitbit logo to appear, then as soon as the logo disappears, release the button, then press and hold the button again. When you feel the vibration, release the button, then wait for the watch to complete the factory reset.
