03-20-2023
17:19
09:59
03-20-2023
17:19
09:59
The strong setting on the alarm vibration is useless! Regretting upgrading from an original versa to a versa 4 with small things I’m finding have gone backwards. Please tell me this is something that will be changed 😬
03-20-2023 18:17
03-20-2023 18:17
Unfortunately nothing will change, but you can certainly play around with the settings to have it go with your needs.
Best Answer03-20-2023 18:37
03-20-2023 18:37
Thanks for your reply. Other than the setting for light & strong do you have any other suggestions? I do have it set to strong now but there is no way that will wake me up 🤣
Best Answer03-20-2023 21:49
03-20-2023 21:49
Hi @Malso74 - the original Versa has good vibrations whereas the Versa 4 doesn't. The only option is to keep the battery fully charged as vibrations, get weaker as the battery level decreases, though you probably won't notice as it is so weak to start with.
The original Versa is a good watch for many reasons, not least of which it has more reliable HR measurements.
03-20-2023 21:56
03-20-2023 21:56
Yep I think I should’ve just lived with the problems I was having. I did have it for nearly 5 years and assumed the 4 would be a step up! Will keep it charged though see if that helps at all but might have to go back to the alarm on my phone 🤷:female_sign:
06-19-2023 15:43
06-19-2023 15:43
I am so sorry I upgraded from a versa 2 to a versa 4.
You would think an upgrade would get you better features.
You would be wrong.
VERSA 4 is an expensive downgrade from the 2.
Totally disappointed with this Fitbit.
DO NOT BUY
06-19-2023 16:28
06-19-2023 16:28
Yes very disappointing!! Thankfully I was able to return mine and I found a versa 2 on sale. Back to working the same as my old one now 😊😊
06-19-2023 19:59
06-19-2023 19:59
Hi @Chrismaslyar - did you know if you are unhappy with the watch and still in the window Fitbit have a 45 day refund policy or possibly authorised dealers too, some stores provide 14 to 30 day refunds.
You can still get another Versa 2 quite cheaply like @Malso74
07-14-2023 03:38
07-14-2023 03:38
Guy is right! He told me the strong vibration was non existent and now I agree with him having gone from a Versa 2 to a Versa 4 over the past week.
I guess I will just set 3 alarms 2 minutes apart.
Really like the Versa 4
