04-30-2023
06:04
12:08
04-30-2023
06:04
12:08
I currently have a charge 3 and its on its last legs. I've been loyal to fitbit for years and always had a good experience so I'd like to upgrade. I'm debating between the sense 2 or versa 4. Both half like all of the features I want...so im trying to determine which is better. main features are obviously the steps, tracking runs, etc. but I am also looking for temperature sensors. One has it but looks like it’s only reading deviations from normal vs the other has a reading and shows deviations. Thanks!
Best AnswerComparing the 2, I see the Sense 2 does list a skin temp sensor but the Versa 2 does not. However that does not mean the Sense 2 reports temperatures. I'm not positive on this, but I think they both report essentially the same thing but the Sense 2 has a specific sensor for it, whereas the Versa 2 tries to infer it somehow from other info. Also keep in mind, this is just skin temp, not internal temp, and is only reported for sleep time. Most find this of limited interest, at most.
I would say the major difference is the ECG app in the Sense 2, which I suppose is useful for some for detecting aFib, but for others, not a factor. And it is only on-demand, not continuous.
Hi @rekhaben92 - you may want to consider instead a Sense or a Versa 3, as these have more features and better flexibility.
