Versa 4 will not charge
I have bought 2 new Fitbits and one charges without issues. However, the second will not charge at all. I have tried both charges sent within the box, wiped/cleaned before charging and even tried my old Versa 4 charger.
Any idea, or should I contact Amazon (where I purchased it)?
3 REPLIES 3
Hi @STAJUK   If you are in the return window, please contact Amazon.
Laurie | Maryland
A warm welcome to the forums @STAJUK.
Thank you for sharing you experience with your new Versa 4 and thank you for trying to fix it on your own.
In addition to the suggestion provided by @LZeeW, you can try to restart the device and confirm that you tried the steps listed in this help article:
Why isn't my Fitbit device's battery charging?
Thanks @LZeeW for your help.
Hi @STAJUK - this can happen also if a tiny bit of plastic still covers one of the contacts on the back of the watch.
Use a magnifying glass to check.
