12-08-2023
15:58
02:46
12-08-2023
15:58
02:46
Does anyone have an issue with the watch not being fully charged 100% as mine seems to stay at 99% for ages, like 30 mins but it never seems to get to 100%?
Best Answer12-08-2023 20:57 - edited 12-08-2023 20:58
Hi @clairechops - charging to 99% is fine, it can take 15 minutes or more to get to 100% and this is time you could be wearing the watch.
The 1% difference will give you perhaps one hour more battery autonomy and spending 30 minutes charging to get an hour is pretty much a waste of time.
This is because at that battery level the charge current is so very small, it takes a long time to get the energy needed.
If you really want to see 100% you can try
12-10-2023 09:15
12-10-2023 09:15
Turning it off this way worked for the 100% charge. Thank you!
